ONTAP EMS reference
monitor.fru events
monitor.fru EMS events occur when ONTAP encounters issues associated with field-replaceable unit (FRU) inventory information.
monitor.fru.info.readable
Severity
INFORMATIONAL
This message occurs when the inventory information about a field-replaceable unit (FRU) that was previously unreadable becomes readable.
Corrective Action
(None).
Syslog Message
The inventory information of FRU %s is readable.
fru_name (STRING): FRU name.
monitor.fru.info.unreadable
Severity
ERROR
This message occurs when the inventory information of a field-replaceable unit (FRU) is not readable.
Corrective Action
See the system hardware guide for the replacement of the FRU. At the earliest convenient time, remove and reinsert the FRU to reseat it, and then resume normal system operation. If the error persists, replace the FRU according to the hardware guide directions.
Syslog Message
The inventory information of FRU %s is not readable.
