The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sp.auth events
Creating your file...
Your file is ready
sp.auth.loginDenied
- Severity
NOTICE
- Description
This message occurs when a login is attempted on the node's Service Processor (SP) or baseboard management controller (BMC) and the login is denied.
- Corrective Action
(None).
- Syslog Message
BMC or SP login authentication failure for user "%s" from %s.
- Parameters
user (STRING): User the login was attempted with.
fromhost (STRING): Where the login was attempted from.
