ONTAP EMS reference
diskown.autoassign events
diskown.autoassign EMS events occur when ONTAP encounters issues associated with automatic disk assignment.
diskown.AutoAssign.MultipleOwners
Severity
ERROR
This message occurs when automatic assigning of a disk fails because the disks on the stack are owned by multiple systems.
Corrective Action
Use the "storage disk show" command to view the list of systems, and then assign all of the disks on this stack to a single system. Or use the "storage disk assign" command to manually assign this disk.
Syslog Message
Automatic assigning failed for disk "%s" (S/N "%s") because the disks on the stack are owned by multiple systems. Automatic assigning failed for all unowned disks on this stack.
diskname (STRING): Name of the disk.
serialno (STRING): Serial number of the disk.
diskown.AutoAssign.MultiplePools
Severity
ERROR
This message occurs when automatic assigning of a disk fails because the disks on the stack are shared across multiple pools.
Corrective Action
Use the "storage disk assign -pool" command to assign all of the disks on this stack to a single pool. Or use the "storage disk assign" command to manually assign this disk.
Syslog Message
Automatic assigning failed for disk "%s" (S/N "%s") because the disks on the stack are shared across multiple pools. Automatic assigning failed for all unowned disks on this stack.
diskown.AutoAssign.NoOwner
Severity
ERROR
This message occurs when automatic assigning of a disk fails because none of the disks on the stack are owned by any system.
Corrective Action
Use the "run local disk show -v" command to get the list of systems and unowned disks. Manually assign one of the disks on this stack by using the "storage disk assign" command.
Syslog Message
Automatic assigning failed for disk "%s" (S/N "%s") because none of the disks on the stack are owned by any system. Automatic assigning failed for all unowned disks on this stack.
