diskown.autoassign events
diskown.AutoAssign.MultipleOwners
- Severity
ERROR
 - Description
This message occurs when automatic assigning of a disk fails because the disks on the loop are owned by multiple systems.
 - Corrective Action
Use the "storage disk show" command to view the list of systems, and then assign all of the disks on this loop to a single system. Or use the "storage disk assign" command to manually assign this disk.
 - Syslog Message
Automatic assigning failed for disk %s (S/N %s) because the disks on the loop are owned by multiple systems. Automatic assigning failed for all unowned disks on this loop.
 - Parameters
diskname (STRING): Name of the disk.
serialno (STRING): Serial number of the disk.
diskown.AutoAssign.MultiplePools
- Severity
ERROR
 - Description
This message occurs when automatic assigning of a disk fails because the disks on the loop are shared across multiple pools.
 - Corrective Action
Use the "storage disk assign -pool" command to assign all of the disks on this loop to a single pool. Or use the "storage disk assign" command to manually assign this disk.
 - Syslog Message
Automatic assigning failed for disk %s (S/N %s) because the disks on the loop are shared across multiple pools. Automatic assigning failed for all unowned disks on this loop.
 - Parameters
diskown.AutoAssign.NoOwner
- Severity
ERROR
 - Description
This message occurs when automatic assigning of a disk fails because none of the disks on the loop are owned by any system.
 - Corrective Action
Use the "run local disk show -v" command to get the list of systems and unowned disks. Manually assign one of the disks on this loop by using the "storage disk assign" command.
 - Syslog Message
Automatic assigning failed for disk %s (S/N %s) because none of the disks on the loop are owned by any system. Automatic assigning failed for all unowned disks on this loop.
 - Parameters
