diskown.autoassign events
diskown.autoassign EMS events occur when ONTAP encounters issues associated with automatic disk assignment.
diskown.AutoAssign.MultipleOwners
- Severity
ERROR
- Description
This message occurs when automatic assigning of a disk fails because the disks on the stack are owned by multiple systems.
- Corrective Action
Use the "storage disk show" command to view the list of systems, and then assign all of the disks on this stack to a single system. Or use the "storage disk assign" command to manually assign this disk.
- Syslog Message
Automatic assigning failed for disk "%s" (S/N "%s") because the disks on the stack are owned by multiple systems. Automatic assigning failed for all unowned disks on this stack.
- Parameters
diskname (STRING): Name of the disk.
serialno (STRING): Serial number of the disk.
diskown.AutoAssign.MultiplePools
- Severity
ERROR
- Description
This message occurs when automatic assigning of a disk fails because the disks on the stack are shared across multiple pools.
- Corrective Action
Use the "storage disk assign -pool" command to assign all of the disks on this stack to a single pool. Or use the "storage disk assign" command to manually assign this disk.
- Syslog Message
Automatic assigning failed for disk "%s" (S/N "%s") because the disks on the stack are shared across multiple pools. Automatic assigning failed for all unowned disks on this stack.
- Parameters
diskown.AutoAssign.NoOwner
- Severity
ERROR
- Description
This message occurs when automatic assigning of a disk fails because none of the disks on the stack are owned by any system.
- Corrective Action
Use the "run local disk show -v" command to get the list of systems and unowned disks. Manually assign one of the disks on this stack by using the "storage disk assign" command.
- Syslog Message
Automatic assigning failed for disk "%s" (S/N "%s") because none of the disks on the stack are owned by any system. Automatic assigning failed for all unowned disks on this stack.
- Parameters
