ONTAP EMS reference
nblade.cifsshrconnectfailed events
nblade.cifsshrconnectfailed EMS events occur when the network blade cannot connect to the path specified in the CIFS share.
Nblade.cifsShrConnectFailed
Severity
ERROR
This message occurs when the network blade cannot connect to the path specified in the CIFS share.
Corrective Action
Verify that the CIFS share path is valid and that the volume it belongs to is accessible.
Syslog Message
Vserver name: %s, Vserver ID: %d, error description: %s, error code: %d, share name: %s, Windows user name: %s, UNIX user name: %s, server IP address: %s, client IP address: %s.
vserverName (STRING): Name for the Vserver associated with this operation.
vserverId (INT): Identifier for the Vserver associated with this operation.
errorDescription (STRING): Description of the error for the CIFS share connection failure.
errorCode (INT): Error code that describes the reason for the CIFS share connection failure.
shareName (STRING): Name of the share to which the connection attempt failed.
domainWinUserName (STRING): Windows domain\user that is attempting to connect to the share.
unixUserName (STRING): UNIX user name.
serverIp (STRING): IP address of the server.
clientIp (STRING): IP address of the client.
