ONTAP EMS reference
connectx.ibunsupportcable events
connectx.ibunsupportcable EMS events occur when an unsupported InfiniBand cable is detected on the InfiniBand port.
connectx.IbUnsupportCable
Severity
ERROR
This message occurs when an unsupported InfiniBand cable is detected on the InfiniBand port.
Corrective Action
Unplug the unsupported InfiniBand cable and plug in a supported cable. Search the support site "Hardware Universe" for information about supported InfiniBand cables.
Syslog Message
Detected unsupported %s on InfiniBand port %s.
cable_type (STRING): InfiniBand cable type.
port_str (STRING): InfiniBand port in which the cable is plugged.
