connectx.ibunsupportcable events
connectx.IbUnsupportCable
- Severity
ERROR
- Description
This message occurs when an unsupported InfiniBand cable is detected on the InfiniBand port.
- Corrective Action
Unplug the unsupported InfiniBand cable and plug in a supported cable. Search the support site "Hardware Universe" for information about supported InfiniBand cables.
- Syslog Message
Detected unsupported %s on InfiniBand port %s.
- Parameters
cable_type (STRING): InfiniBand cable type.
port_str (STRING): InfiniBand port in which the cable is plugged.
