ONTAP EMS reference
cpeer.authentication events
cpeer.authentication EMS events occur when ONTAP encounters issues associated with authentication of cluster peer relationships.
cpeer.authentication.create
Severity
NOTICE
This message occurs when authentication is successfully established with a peer cluster.
Corrective Action
(None).
Syslog Message
The peering relationship with cluster %s is now authenticated.
peer (STRING): Peer cluster with which this cluster is now mutually authenticated.
cpeer.authentication.disable
Severity
NOTICE
This message occurs when authentication is disabled for a cluster peer relationship.
Corrective Action
(None).
Syslog Message
The peering relationship with cluster %s is now unauthenticated.
peer (STRING): Peer cluster that is now peered to this cluster without authentication.
cpeer.authentication.revoke
Severity
ERROR
This message occurs when authentication is revoked for a cluster peer relationship.
Corrective Action
Modify the relationship to match on both of the peered clusters. To have them agree on an unauthenticated relationship, use the 'cluster peer modify -authentication no-auth' command. To have them agree on an authenticated relationship, use the same passphrase with the 'cluster peer modify -authentication use-auth' command.
Syslog Message
The peering relationship with cluster %s is now revoked and is no longer functional.
peer (STRING): Peer cluster for which the peering relationship has had its peering authentication revoked.
cpeer.authentication.viol
Severity
NOTICE
This message occurs when a cross-cluster access should be authenticated, but is not. The access has been denied successfully.
Corrective Action
(None).
Syslog Message
Access as peer cluster %s was claimed from network address %s, but has not been granted because %s.
peer (STRING): Peer cluster on behalf of which this access was made.
remoteAddress (STRING): Remote network address of the violating connection.
reason (STRING): Justification for the violation claim.
