ONTAP EMS reference
cpeer.authentication events
cpeer.authentication.create
Severity
NOTICE
This message occurs when authentication is successfully established with a peer cluster.
Corrective Action
(None).
Syslog Message
The peering relationship with cluster %s is now authenticated.
peer (STRING): Peer cluster with which this cluster is now mutually authenticated.
cpeer.authentication.disable
Severity
NOTICE
This message occurs when authentication is disabled for a cluster peer relationship.
Corrective Action
(None).
Syslog Message
The peering relationship with cluster %s is now unauthenticated.
peer (STRING): Peer cluster that is now peered to this cluster without authentication.
cpeer.authentication.revoke
Severity
ERROR
This message occurs when authentication is revoked for a cluster peer relationship.
Corrective Action
Modify the relationship to match on both of the peered clusters. To have them agree on an unauthenticated relationship, use the 'cluster peer modify -authentication no-auth' command. To have them agree on an authenticated relationship, use the same passphrase with the 'cluster peer modify -authentication use-auth' command.
Syslog Message
The peering relationship with cluster %s is now revoked and is no longer functional.
peer (STRING): Peer cluster for which the peering relationship has had its peering authentication revoked.
cpeer.authentication.viol
Severity
NOTICE
This message occurs when a cross-cluster access should be authenticated, but is not. The access has been denied successfully.
Corrective Action
(None).
Syslog Message
Access as peer cluster %s was claimed from network address %s, but has not been granted because %s.
peer (STRING): Peer cluster on behalf of which this access was made.
remoteAddress (STRING): Remote network address of the violating connection.
reason (STRING): Justification for the violation claim.
