ONTAP EMS reference
rpt.disk events
rpt.disk EMS events occur when the generation of a disk UUID fails.
rpt.disk.uuid.gen.failed
Severity
ERROR
This message occurs when the generation of a disk UUID fails.
Corrective Action
Investigate the Directed Attached (DA) disk to fix the error, and then reboot the device.
Syslog Message
Disk name %s and disk unit number %d of RAID passthru with error message %s.
d_name (STRING): Disk name.
d_unit (INT): Unit number.
errmsg (STRING): Whether the device failed or is misconfigured.
