ONTAP EMS reference
diskown.rescan events
diskown.rescan EMS events occur when ONTAP encounters issues associated with disk ownership updates over the HA messaging layer.
diskown.rescan.notConnected
Severity
ERROR
This message occurs when the high-availability (HA) messaging layer fails to connect to the specified node for disk ownership updates.
Corrective Action
Run the command "run local disk show -v" from the node specified in the node parameter to correct disk ownership.
Syslog Message
HA messaging layer on the local node failed to connect to node %s for disk ownership updates.
node (STRING): Name of the node where disk ownership might be outdated.
status (INT): Error number returned by the HA messaging layer from the HA message error space.
scope (INT): Internal scope identifier for the module that returned the error.
scope_err (INT): Internal error number returned by the module.
diskown.rescan.notSent
Severity
ERROR
This message occurs when the high-availability (HA) messaging layer fails to send a disk ownership update message.
Corrective Action
Syslog Message
HA messaging layer on the local node failed to send a disk ownership update message to node %s.
