diskown.rescan events
diskown.rescan.notConnected
- Severity
ERROR
 - Description
This message occurs when the high-availability (HA) messaging layer fails to connect to the specified node for disk ownership updates.
 - Corrective Action
Run the command "run local disk show -v" from the node specified in the node parameter to correct disk ownership.
 - Syslog Message
HA messaging layer on the local node failed to connect to node %s for disk ownership updates.
 - Parameters
node (STRING): Name of the node where disk ownership might be outdated.
status (INT): Error number returned by the HA messaging layer from the HA message error space.
scope (INT): Internal scope identifier for the module that returned the error.
scope_err (INT): Internal error number returned by the module.
diskown.rescan.notSent
- Severity
ERROR
 - Description
This message occurs when the high-availability (HA) messaging layer fails to send a disk ownership update message.
 - Corrective Action
 - Syslog Message
HA messaging layer on the local node failed to send a disk ownership update message to node %s.
 - Parameters
