ONTAP EMS reference
dm.vserver events
dm.vserver EMS events occur when ONTAP encounters issues associated with Vserver configuration replication.
dm.vserver.mcc.rebaselinefailed
Severity
ERROR
This message occurs when resynchronization of the Vserver configuration failed in a MetroCluster(tm) configuration.
Corrective Action
Use the "metrocluster vserver resync" command to resynchronize the Vserver configuration.
Syslog Message
Vserver configuration resynchronization failed for Vserver %s.
vserver (STRING): Name of the Vserver whose configuration is being replicated.
dm.vserver.sm.rebaselinefailed
Severity
ERROR
This message occurs when resynchronization of the Vserver configuration failed in a Vserver DR relationship.
Corrective Action
Use the "snapmirror resync" command to resynchronize the Vserver configuration.
Syslog Message
dm.vserver.unlockfailed
Severity
ERROR
This message occurs when unlocking the Vserver failed after resynchronization of the Vserver configuration in a MetroCluster(tm) configuration or Vserver DR setup. Management operations on this Vserver will fail, until an unlock operation is done by the admin manually.
Corrective Action
Use the "vserver unlock -force true" command at diagnostic privilege to manually unlock the Vserver.
Syslog Message
Vserver unlock failed for Vserver %s.
vserver (STRING): Name of the Vserver whose unlock operation failed.
