ONTAP EMS reference
nblade.vscanworkqueueoverloaded events
nblade.vscanworkqueueoverloaded EMS events occur when there are too many events being generated by the Vscan subsystem in ONTAP® software, which might be the result of a misconfigured Vscan server.
Nblade.vscanWorkQueueOverloaded
Severity
NOTICE
This message occurs when there are too many events being generated by the Vscan subsystem in ONTAP® software, which might be the result of a misconfigured Vscan server.
Corrective Action
Check the Vscan server configurations to make sure that there are no connectivity or configuration issues between the storage system and Vscan server. Use the "vserver vscan connection-status show-all" command to see the connection states of all configured Vscan servers.
Syslog Message
Too many events [%d] present in Vscan work queue.
workQueueDepth (INT): Number of queued events waiting to be processed.
