nblade.vscanworkqueueoverloaded events
Creating your file...
Your file is ready
Nblade.vscanWorkQueueOverloaded
- Severity
NOTICE
- Description
This message occurs when there are too many events being generated by the Vscan subsystem in ONTAP® software, which might be the result of a misconfigured Vscan server.
- Corrective Action
Check the Vscan server configurations to make sure that there are no connectivity or configuration issues between the storage system and Vscan server. Use the "vserver vscan connection-status show-all" command to see the connection states of all configured Vscan servers.
- Syslog Message
Too many events [%d] present in Vscan work queue.
- Parameters
workQueueDepth (INT): Number of queued events waiting to be processed.
