ONTAP EMS reference
protocol.exportcheckfailed events
protocol.exportcheckfailed EMS events occur when there is an export check failure due to, either export-policy configuration not allowing access, or a non-existing filesystem/junction access attempt.
protocol.exportCheckFailed
Severity
ERROR
This message occurs when there is an export check failure due to, either export-policy configuration not allowing access, or a non-existing filesystem/junction access attempt.
Corrective Action
Check the export policy configuration or filesystem name depending on the reason due to which export access check failed.
Syslog Message
Export access check failed on Vserver %s for client %s, trying to access volume %s, having policy %s, via protocol %s. Reason: %s
vserver (STRING): Name of the Vserver where the issue occurs.
clientIP (STRING): Client for which the export access check failure happened.
volumeName (STRING): Volume name for which export access check failed.
policyName (STRING): Name of the export policy from which export access check failed.
protocol (STRING): Access protocol used by client for filesystem access.
reason (STRING): Reason for which export access check failed.
