ONTAP EMS reference
wafl.snapshot events
wafl.snapshot EMS events occur when ONTAP encounters issues associated with snapshot metadata consistency.
wafl.snapshot.badFilesize
Severity
NOTICE
This event is issued when the system discover that a filesize is out of range in a snapshot.
Corrective Action
(None).
Syslog Message
File size out of range in snapshot.
(None).
wafl.snapshot.badLevel
Severity
NOTICE
This event is issued when there is an inconsistency in the metadata of an inode in a snapshot. This message is advisory only. The inconsistency will be corrected in memory only, and the data will be made available.
Corrective Action
No action is required; however, the message may repeat until the snapshot is deleted.
Syslog Message
Corrected bad level %d for buftree of %s fileid %d, snapid %d in %s %s%s%s%s
level (INT): The level of the buftree of the file
ino_type (STRING): The inode type
fileid (INT): The file identifier
snapid (INT): The snapshot identifier
type (STRING): The type of object (volume/aggregate)
owner (STRING): The owner of the volume
vol (STRING): The name of the volume
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.snapshot.ecv.fail
Severity
ERROR
This message occurs when the system attempts to create a snapshot on a mixed-version cluster. However, the effective version of the cluster is ONTAP® 9.3 or earlier, and the maximum number of snapshots supported by this effective version has already been reached.
Corrective Action
Upgrade all nodes in the cluster to ONTAP 9.4 or later.
Syslog Message
Snapshot create operation failed on volume %s%s%s. Maximum number of snapshots reached on a mixed-version cluster.
vol (STRING): Name of the volume.
volident (STRING): ID of the volume.
