wafl.snapshot events
wafl.snapshot.badFilesize
- Severity
NOTICE
 - Description
This event is issued when the system discover that a filesize is out of range in a snapshot.
 - Corrective Action
(None).
 - Syslog Message
File size out of range in snapshot.
 - Parameters
(None).
wafl.snapshot.badLevel
- Severity
NOTICE
 - Description
This event is issued when there is an inconsistency in the metadata of an inode in a snapshot. This message is advisory only. The inconsistency will be corrected in memory only, and the data will be made available.
 - Corrective Action
No action is required; however, the message may repeat until the snapshot is deleted.
 - Syslog Message
Corrected bad level %d for buftree of %s fileid %d, snapid %d in %s %s%s%s%s
 - Parameters
level (INT): The level of the buftree of the file
ino_type (STRING): The inode type
fileid (INT): The file identifier
snapid (INT): The snapshot identifier
type (STRING): The type of object (volume/aggregate)
owner (STRING): The owner of the volume
vol (STRING): The name of the volume
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.snapshot.ecv.fail
- Severity
ERROR
 - Description
This message occurs when the system attempts to create a snapshot on a mixed-version cluster. However, the effective version of the cluster is ONTAP® 9.3 or earlier, and the maximum number of snapshots supported by this effective version has already been reached.
 - Corrective Action
Upgrade all nodes in the cluster to ONTAP 9.4 or later.
 - Syslog Message
Snapshot create operation failed on volume %s%s%s. Maximum number of snapshots reached on a mixed-version cluster.
 - Parameters
vol (STRING): Name of the volume.
volident (STRING): ID of the volume.
