ONTAP EMS reference
fci.loop events
fci.loop EMS events occur when the Fibre Channel loop generates too many loop initialization events.
fci.loop.stability
Severity
ERROR
This message occurs when the Fibre Channel loop generates too many loop initialization events. This can be a sign of unstable hardware.
Corrective Action
If the adapter is in use check cabling, and if it is connected to disk shelves check the seating of the LRC/ESH cards and disks. If this does not resolve the issue, contact NetApp technical support for assistance in diagnosing a Fibre Channel issue.
Syslog Message
Fibre Channel adapter %s has a loop stability problem. %d loop-initialization events seen in %d seconds.
adapterName (STRING): Name of the associated Fibre Channel host bus adapter.
numLips (INT): Number of loop-initialization events that occurred.
numSeconds (INT): Time interval that these loop-initialization events were seen.
