fci.loop events
fci.loop EMS events occur when the Fibre Channel loop generates too many loop initialization events.
fci.loop.stability
- Severity
ERROR
- Description
This message occurs when the Fibre Channel loop generates too many loop initialization events. This can be a sign of unstable hardware.
- Corrective Action
If the adapter is in use check cabling, and if it is connected to disk shelves check the seating of the LRC/ESH cards and disks. If this does not resolve the issue, contact NetApp technical support for assistance in diagnosing a Fibre Channel issue.
- Syslog Message
Fibre Channel adapter %s has a loop stability problem. %d loop-initialization events seen in %d seconds.
- Parameters
adapterName (STRING): Name of the associated Fibre Channel host bus adapter.
numLips (INT): Number of loop-initialization events that occurred.
numSeconds (INT): Time interval that these loop-initialization events were seen.
