ONTAP EMS reference
vifmgr.bd events
vifmgr.bd EMS events occur when ONTAP encounters issues associated with broadcast domain configuration.
vifmgr.bd.badmtu
Severity
ERROR
This message occurs when an MTU is entered on a Broadcast Domain that its member ports cannot support. The ports that failed will continue using their present values.
Corrective Action
Change the MTU of the Broadcast Domain to a value supported by all member ports.
Syslog Message
In IPspace %s, Broadcast Domain %s has an MTU of %d, which is not supported by the following ports: %s.
ipspace (STRING): Name of the IPspace in which the Broadcast Domain resides.
broadcast_domain (STRING): Name of the Broadcast Domain.
mtu (INT): MTU of the Broadcast Domain.
port_names (STRING): Ports in the Broadcast Domain that are failing.
vifmgr.bd.conflicts
Severity
ERROR
This message occurs when the administrator modifies properties of a node management LIF while the node is out of quorum, and the broadcast domain of the home port, current port, and subnet are not all the same.
Corrective Action
The node management LIF's configuration before the node went out of quorum was automatically applied. You can change this configuration now that the node is online.
Syslog Message
LIF %s had mismatching broadcast domains. The previous values were: home-port (%s), current-port (%s), and subnet (%s).
LIF (STRING): Name of the LIF.
home_port_bd (STRING): Broadcast domain name of this LIF's home port prior to going out of quorum.
current_port_bd (STRING): Broadcast domain name of this LIF's current port prior to going out of quorum.
sub_bd (STRING): Broadcast domain name of this LIF's subnet prior to going out of quorum.
