vifmgr.bd events
Creating your file...
vifmgr.bd.badmtu
- Severity
ERROR
- Description
This message occurs when an MTU is entered on a Broadcast Domain that its member ports cannot support. The ports that failed will continue using their present values.
- Corrective Action
Change the MTU of the Broadcast Domain to a value supported by all member ports.
- Syslog Message
In IPspace %s, Broadcast Domain %s has an MTU of %d, which is not supported by the following ports: %s.
- Parameters
ipspace (STRING): Name of the IPspace in which the Broadcast Domain resides.
broadcast_domain (STRING): Name of the Broadcast Domain.
mtu (INT): MTU of the Broadcast Domain.
port_names (STRING): Ports in the Broadcast Domain that are failing.
vifmgr.bd.conflicts
- Severity
ERROR
- Description
This message occurs when the administrator modifies properties of a node management LIF while the node is out of quorum, and the broadcast domain of the home port, current port, and subnet are not all the same.
- Corrective Action
The node management LIF's configuration before the node went out of quorum was automatically applied. You can change this configuration now that the node is online.
- Syslog Message
LIF %s had mismatching broadcast domains. The previous values were: home-port (%s), current-port (%s), and subnet (%s).
- Parameters
LIF (STRING): Name of the LIF.
home_port_bd (STRING): Broadcast domain name of this LIF's home port prior to going out of quorum.
current_port_bd (STRING): Broadcast domain name of this LIF's current port prior to going out of quorum.
sub_bd (STRING): Broadcast domain name of this LIF's subnet prior to going out of quorum.
