ONTAP EMS reference
sm.xfer events
sm.xfer EMS events occur when ONTAP encounters issues associated with SnapMirror® transfer operations.
sm.xfer.fail.del.snap
Severity
ERROR
This message occurs when deletion of a snapshot on the destination volume fails, and therefore a subsequent transfer exceeds the maximum supported snapshot count for the vault destination.
Corrective Action
Manually delete the snapshots from the destination volume and reissue the failed SnapMirror command.
Syslog Message
Unable to delete snapshot '%s' from destination volume '%s' of the relationship with relationship UUID '%s' to make space for for newer snapshots.
snap_name (STRING): Snapshot that was not deleted.
dst_path (STRING): Destination volume of the relationship.
relationship_id (STRING): UUID of the snapmirror relationship.
sm.xfer.fail.maxlim.snap
Severity
ALERT
This message occurs when a SnapMirror® transfer fails because the maximum supported snapshot limit for a SnapMirror destination is reached and there is no space for a new, incoming snapshot.
Corrective Action
Reduce the "keep" count by using the "snapmirror policy modify-rule -policy [policy_name] -keep [keep_count]" command, or by manually deleting snapshots from the SnapMirror® destination.
Syslog Message
The number of snapshots on destination volume '%s' of the relationship with relationship UUID '%s' and policy '%s' has reached the maximum supported.
policy_name (STRING): SnapMirror policy name.
sm.xfer.incr.snap.rename
Severity
ERROR
This message occurs when an incomplete SnapMirror® operation is detected for an incremental snapshot that no longer exists on the SnapMirror® source volume. As a result, SnapMirror creates a snapshot with the name "snapmirror_vlt_xfer_recovery" and requires a SnapMirror Resync operation to be performed on the SnapVault relationship to resume data protection.
Corrective Action
Resume data protection either by retaining or deleting the snapshot Use the 'snapmirror resync -preserve' to retain it or use the 'snapmirror resync' command to delete it.
Syslog Message
An incomplete SnapMirror operation was detected for an incremental snapshot that no longer exists on the source volume '%s'. The data transfer for the incremental snapshot was completed but the snapshot on the vault destination '%s' was not created. Instead, a snapshot with the name "snapmirror_vlt_xfer_recovery" was created.
src_path (STRING): Source volume of the relationship.
sm.xfer.no.new.snap
Severity
INFORMATIONAL
This message occurs when a SnapMirror® update does not find any new snapshots to transfer. This can happen when none of the newer snapshots on the source has a SnapMirror® label that matches a SnapMirror policy.
Corrective Action
Check that the SnapMirror label from the snapshot policy matches SnapMirror policy rules.
Syslog Message
SnapMirror update did not find any new snapshots to transfer from the source volume '%s' of the relationship with relationship UUID '%s'.
src_path (STRING): Source volume of the SnapMirror relationship.
sm.xfer.same.name.snap.dst
Severity
ERROR
This message occurs when a snapshot was not transferred from the source volume to the destination volume during a snapmirror transfer because a snapshot with the same name already exists in the destination volume.
Corrective Action
Rename the snapshot in the source volume to a name that does not match the name of any snapshot in the destination volume. Then, wait for the next scheduled update or trigger a manual snapmirror update.
Syslog Message
Snapshot "%s" was not transferred from the source volume "%s" to the destination volume "%s" because the destination volume has a snapshot with the same name.
snap_name (STRING): Name of the snapshot that was not transferred.
sm.xfer.warn.limit
Severity
ERROR
This message occurs when a SnapMirror® transfer receives a warning when it is approaching the "keep" count of a particular SnapMirror® relationship.
Corrective Action
Increase the "keep" count to transfer more snapshots with the same label using the following command: snapmirror policy modify-rule -policy [policy_name] -keep [keep_count]
Syslog Message
Warnings issued for SnapMirror relationship with source volume '%s' and destination volume '%s' with relationship UUID '%s' : %s
warn_str (STRING): SnapMirror transfer warning.
sm.xfer.warn.snapshot.count.limit
Severity
ERROR
This message occurs during a SnapMirror® transfer, when the snapshot count limit is reached for the SnapMirror relationship between the indicated source and destination volumes.
Corrective Action
Delete some snapshots from the destination volume to create space for new snapshots to be transferred to it.
Syslog Message
Snapshot count limit for SnapMirror relationship with source volume '%s' and destination volume '%s' with relationship UUID '%s' has been reached : %s
dst_path (STRING): Destination volume of the SnapMirror relationship.
