ONTAP EMS reference
vifmgr.cluscheck events
vifmgr.cluscheck EMS events occur when ONTAP encounters issues associated with cluster logical interface (LIF) connectivity.
vifmgr.cluscheck.assigned
Severity
NOTICE
This message occurs when the named cluster logical interface (LIF) was not assigned to any network port and is now assigned to a port.
Corrective Action
(None).
Syslog Message
Cluster LIF %s (node %s) is now assigned to port %s.
lif_name (STRING): Name of cluster LIF that was not assigned to a network port but now is.
node_name (STRING): Name of the node on which the cluster LIF that was not assigned to a port now resides.
port_name (STRING): Name of the port to which the LIF is now assigned.
vifmgr.cluscheck.badping
Severity
NOTICE
This message occurs when the ping test for cluster logical interface (LIF) interconnectivity displays unexpected results.
Corrective Action
Ensure connectivity amoung the cluster LIFs. Several issues that can cause this problem. Some things to check include the following: - Port connectivity to the correct network or switch - Link connectivity - Proper switch configuration - Proper LIF configuration
Syslog Message
Cluster check ping command (%s) failed: %d, %s.
cmd_line (STRING): Ping test command line.
exit_status (INT): Ping test result.
cmd_output (STRING): Ping test command output.
vifmgr.cluscheck.crcerrors
Deprecated
Deprecated as of version 9.8.0 and replaced by vifmgr.cluscheck.hwerrors.
Severity
ALERT
This message occurs when a network device reports a high number of observed hardware errors, such as CRC errors, length errors, alignment errors, or dropped frames.
Corrective Action
The errors could be originating from the specified port, a remote port, or a port on another component of the network. Check the statistics for both the port and the switch. Contact NetApp technical support for assistance and specific instructions.
Syslog Message
Port %s on node %s is reporting a high number of observed hardware errors, possibly CRC errors.
portname (STRING): Name of the device that is reporting a high number of hardware errors.
nodename (STRING): Name of the node on which the port resides.
vifmgr.cluscheck.ctdpktloss
Severity
ALERT
This message occurs when continued packet loss during the ping test is observed. Continued packet loss means multiple failures of the ping test persisted over several iterations of the test. The ping test tests the connectivity of a cluster logical interface (LIF) to all other cluster logical interfaces (LIFs).
Corrective Action
Ensure connectivity of the cluster LIFs. There are a number of issues that can cause this problem. Some things to check: - is the port connected to the correct network/switch - link light - switch configuration
Syslog Message
Continued packet loss when pinging from cluster lif %s (node %s) to cluster lif %s (node %s).
src_vif (STRING): Name of the source cluster LIF.
src_node (STRING): Node name of the source cluster LIF.
dst_vif (STRING): Name of the desination cluster LIF.
dst_node (STRING): Node name of the destination cluster LIF.
vifmgr.cluscheck.droppedall
Severity
ALERT
This message occurs when all packets of the ping test are dropped. The ping test tests the connectivity of a cluster logical interface (LIF) to all other cluster logical interfaces (LIFs).
Corrective Action
Syslog Message
Total packet loss when pinging from cluster lif %s (node %s) to cluster lif %s (node %s).
vifmgr.cluscheck.droppedlarge
Severity
ALERT
This message occurs when all of the packets in the large packet ping test are dropped. This most likely suggests an MTU misconfiguration. The ping test tests the connectivity of a cluster logical interface (LIF) to all other cluster logical interfaces (LIFs).
Corrective Action
First, resolve any outstanding instances of vifmgr.cluscheck.mtumismatch. Second, verify that the cluster switches themselves are configured to support the same MTU as configured for the cluster LIFs.
Syslog Message
Partial packet loss when pinging from cluster lif %s (node %s) to cluster lif %s (node %s).
vifmgr.cluscheck.droppednone
Severity
NOTICE
This message occurs when all packets of the ping test are now successfully received. The ping test verifies the connectivity of a cluster logical interface (LIF) to all other cluster LIFs.
Corrective Action
(None).
Syslog Message
No packet loss when pinging from cluster LIF: %s (node: %s) to cluster LIF: %s (node: %s).
dst_vif (STRING): Name of the destination cluster LIF.
Severity
ALERT
Corrective Action
Syslog Message
Port %s on node %s is reporting a high number (at least 1 per %d packets) of observed hardware errors (CRC, length, alignment, dropped).
threshold (INT): Threshold at which this message is logged, at least 1 error per threshold.
vifmgr.cluscheck.hwerrors.ifgrp
Severity
NOTICE
This message occurs when a network device that is part of an interface group reports a high number of observed hardware errors, such as CRC errors (cyclic redundancy check), length errors, alignment errors, or dropped frames, and those errors are limited to a single network interface card (NIC) slot.
Corrective Action
Syslog Message
Ifgrp member port %s on node %s is reporting a high number (at least one per %d packets) of hardware errors. No other NIC slot in the ifgrp is over threshold.
threshold (INT): An event is emitted when one or more errors occur for this number of packets.
vifmgr.cluscheck.l2ping
Severity
EMERGENCY
This message occurs when the l2ping test fails. This test verifies L2 reachability between cluster ports. This condition typically results in loss of communication between the two nodes.
Corrective Action
Verify that the cable is plugged in properly to both the NIC and the switch, and that the switch is powered on. If these conditions are met and the cluster link remains down, contact NetApp technical support to investigate further.
Syslog Message
l2ping failure when pinging from cluster port %s (node %s) to cluster port %s (node %s).
src_prt (STRING): Name of the source cluster port.
src_node (STRING): Node name of the source cluster port.
dst_port (STRING): Name of the desination cluster port.
dst_node (STRING): Node name of the destination cluster port.
vifmgr.cluscheck.lifdown
Severity
NOTICE
This message occurs when the named cluster logical interface (LIF) is configured administratively "down".
Corrective Action
Use the "network interface modify" command to change the status-admin value of the LIF to "up".
Syslog Message
Cluster LIF %s is administratively "down".
lif_name (STRING): Name of the LIF that is currently inactive.
vifmgr.cluscheck.lifup
Severity
NOTICE
This message occurs when a cluster logical interface (LIF) was configured administratively "down" and is now configured administratively "up".
Corrective Action
(None).
Syslog Message
Cluster LIF %s is administratively "up".
lif_name (STRING): Name of the LIF that is currently active.
vifmgr.cluscheck.mtumatch
Severity
ALERT
This message occurs when the Maximum Transmission Unit (MTU) of a port assigned to a cluster logical interface (LIF) did not match the MTU of a port assigned to a different cluster logical interface but now does match.
Corrective Action
(None).
Syslog Message
MTU %s on cluster port %s (node %s) now matchs MTU %s on cluster port %s (node %s).
src_mtu (STRING): MTU of the source cluster LIF port.
src_port (STRING): Name of the source cluster LIF port.
src_node (STRING): Name of the source node on which source cluster LIF port resides.
dst_mtu (STRING): MTU of the destination cluster LIF port.
dst_port (STRING): Name of the destination cluster LIF port.
dst_node (STRING): Name of the node on which destination cluster LIF port resides.
Severity
ALERT
This message occurs when the Maximum Transmission Unit (MTU) of a port assigned to a cluster logical interface (LIF) does not match the MTU of a port assigned to a different cluster logical interface. This condition may cause loss of packets between these two LIFs.
Corrective Action
Ensure the that MTUs of the LIFs are identical. The "network port show" command will display the port MTU settings. Any mismatched MTUs can modified from the "network port" subcommand.
Syslog Message
MTU %s on cluster port %s (node %s) does not match MTU %s on cluster port %s (node %s).
vifmgr.cluscheck.notassigned
Severity
ALERT
This message occurs when the named cluster logical interface (LIF) is not assigned to any network port.
Corrective Action
Verify that the LIF's current port is configured administratively "up". Use the "network interface show" command to determine the current port of the LIF. Use the "network port show -fields up-admin" command to show the port's administrative state. Ensure that the network cabling connecting the remote network port is in place and secure. Ensure that the remote network port is configured administratively "up". If the port's link state is "up", attempt to migrate the cluster LIF to another cluster port. Use the "network port show" command to view the port's link state. If the current port is "up", use the "network interface migrate" command to migrate the LIF to another port.
Syslog Message
Cluster LIF %s (node %s) is not assigned to any port.
lif_name (STRING): Name of the cluster LIF.
node_name (STRING): Name of the node on which the cluster LIF resides.
vifmgr.cluscheck.sameRmtDev
Severity
ERROR
This message occurs when the home ports of the two cluster LIFs used for internal cluster replicated database (RDB) operations are connected to the same cluster switch. These LIFs should be connected to different cluster switches for optimal cluster resiliency.
Corrective Action
Use the "network port show -ipspace Cluster -fields remote-device-id" command to verify that the home ports of the specified cluster LIFs are connected to different cluster switches. If necessary, re-home one of the cluster LIFs to a port that is connected to the other switch. For help, search the NetApp knowledge base for "ONTAP Cluster interconnect management communication is improperly configured".
Syslog Message
Cluster LIFs "%s" and "%s" on node "%s" are used for RDB operations. The home ports of these LIFs are connected to the same cluster switch: "%s".
clus1_lif (STRING): Name of a cluster LIF.
clus2_lif (STRING): Name of a cluster LIF.
node (STRING): Node name of the cluster LIFs.
remote_device (STRING): Name of the cluster switch.
