ONTAP EMS reference
netif.hangdetected events
netif.hangdetected EMS events occur when a network interface driver detects that an interface is hung.
netif.hangDetected
Severity
ERROR
This message occurs when a network interface driver detects that an interface is hung.
Corrective Action
If hardware is reset and there are no further hangs, no corrective action is required. Otherwise, if the system reports frequent hangs, a core dump is forced, or no action is taken by the driver, contact NetApp technical support.
Syslog Message
Network interface %s hung (%s). %s. Driver: %s.
ifName (STRING): Name of the network interface: for example, "e4a".
hangType (STRING): Type of hang. For example, "transmit", "PCIe RcvMstAbt".
recoveryAction (STRING): Action, if any, that will be taken by the driver to recover. For example, "Resetting to recover" or "Forcing panic for core dump" (for root cause analysis).
driver (STRING): Driver name.
