ONTAP EMS reference
snaplock.ss events
snaplock.ss EMS events occur when ONTAP encounters issues associated with SnapLock® snapshot state.
snaplock.ss.lockBadVolume
Severity
ALERT
This event is generated if an attempt is made to lock a snapshot on a SnapLock volume that has previously failed to find or load its SnapLock snapshot state.
Corrective Action
Run wafliron on the volume.
Syslog Message
A snapshot on SnapLock volume '%s%s' on the Vserver with ID '%s', could not be locked because the SnapLock snapshot state could not be found or loaded for the volume.
volume (STRING): The name of the SnapLock volume on which the snapshot could not be locked.
app (STRING): Application Name.
volident (STRING): Unique identifier of the volume when the volume name itself is insufficient.
snaplock.ss.state.badMagic
Severity
ALERT
This event is generated if the SnapLock snapshot state on a SnapLock volume is corrupt with an invalid magic file identifier. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
Corrective Action
Run wafliron on this volume.
Syslog Message
The SnapLock snapshot state is corrupt with an invalid magic file identifier on SnapLock volume '%s%s' on the Vserver with ID '%s'.
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state is corrupt with an invalid magic file identifier.
snaplock.ss.state.badSize
Severity
ALERT
This event is generated if the SnapLock snapshot state on a SnapLock volume is corrupt with an incorrect size. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
Corrective Action
Syslog Message
The SnapLock snapshot state is corrupt with an incorrect size on SnapLock volume '%s%s' on the Vserver with ID '%s'.
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state is corrupt with an incorrect size.
snaplock.ss.state.badState
Severity
ERROR
This message occurs when SnapLock® Snapshot® copies on the volume are corrupted, which prevents updates on the lockvault from succeeding until this is corrected.
Corrective Action
Run the "snapshot fix-snaplock-state" command on this volume.
Syslog Message
The SnapLock snapshot state is corrupt on SnapLock volume '%s%s' on the Vserver with ID '%s'.
volume (STRING): Name of the SnapLock volume on which the SnapLock Snapshot state is corrupt.
snaplock.ss.state.badVersion
Severity
ALERT
This event is generated if the SnapLock snapshot state on a SnapLock volume has an invalid version number. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
Corrective Action
Syslog Message
The SnapLock snapshot state has an invalid version number on SnapLock volume '%s%s' on the Vserver with ID '%s'. The bad version number found was %d and the expected version was %d.
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state has an invalid version number.
bad_version (INT): The invalid version number of the SnapLock snapshot state.
expected_version (INT): The expected version number of the SnapLock snapshot state.
snaplock.ss.state.createFail
Severity
ALERT
This event is generated if SnapLock is unable to create the state for the SnapLock snapshot state on a SnapLock volume. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
Corrective Action
Syslog Message
Failed to create the SnapLock snapshot state on SnapLock volume '%s%s' on the Vserver with ID '%s'.
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state could not be created.
snaplock.ss.state.dir.createFail
Severity
ALERT
This event is generated if SnapLock is unable to create the SnapLock state directory for storage of SnapLock state on a SnapLock volume.
Corrective Action
Syslog Message
Failed to create the SnapLock state directory for storage of SnapLock state on SnapLock volume '%s%s' on the Vserver with ID '%s'.
volume (STRING): The name of the SnapLock volume on which the SnapLock state directory could not be created.
snaplock.ss.state.loadFail
Severity
ALERT
This event is generated if the SnapLock snapshot state on a SnapLock volume failed to load. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
Corrective Action
Syslog Message
The SnapLock snapshot state could not be loaded from SnapLock volume '%s%s' on the Vserver with ID '%s'.
volume (STRING): The name of the SnapLock volume from which the SnapLock snapshot state could not be loaded.
snaplock.ss.state.notFound
Severity
ALERT
This event is generated if the SnapLock snapshot state cannot be found on a SnapLock volume. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
Corrective Action
Syslog Message
The SnapLock snapshot state could not be found on SnapLock volume '%s%s' on the Vserver with ID '%s'.
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state could not be found.
snaplock.ss.state.upgradeFail
Severity
ALERT
This event is generated if SnapLock is unable to upgrade the the SnapLock snapshot state on a SnapLock volume. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
Corrective Action
Syslog Message
Failed to upgrade the SnapLock snapshot state to SnapLock volume '%s%s' on the Vserver with ID '%s'.
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state could not be written.
snaplock.ss.state.writeFail
Severity
ALERT
This event is generated if SnapLock is unable to write the the SnapLock snapshot state on a SnapLock volume. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
Corrective Action
Syslog Message
Failed to write the SnapLock snapshot state to SnapLock volume '%s%s' on the Vserver with ID '%s'.
