ONTAP EMS reference
nv.rename events
nv.rename EMS events occur when ONTAP encounters issues associated with file renaming after NVRAM failures.
nv.rename.err
Severity
INFORMATIONAL
This message occurs when there is an error while renaming the files specified in /etc/nvfail_rename.
Corrective Action
(None).
Syslog Message
nvfail_rename: %s: %s.
fileName (STRING): File name.
error (STRING): Error string.
nv.rename.files
Severity
INFORMATIONAL
This message occurs while renaming the files specified in /etc/nvfail_rename.
Corrective Action
(None).
Syslog Message
Renaming files specified in /etc/nvfail_rename.
(None).
nv.rename.longName
Severity
INFORMATIONAL
This message occurs while renaming the files specified in /etc/nvfail_rename, when the file name is too long.
Corrective Action
(None).
Syslog Message
nvfail_rename: %s: File name too long.
