nv.rename events
nv.rename EMS events occur when ONTAP encounters issues associated with file renaming after NVRAM failures.
nv.rename.err
- Severity
INFORMATIONAL
- Description
This message occurs when there is an error while renaming the files specified in /etc/nvfail_rename.
- Corrective Action
(None).
- Syslog Message
nvfail_rename: %s: %s.
- Parameters
fileName (STRING): File name.
error (STRING): Error string.
nv.rename.files
- Severity
INFORMATIONAL
- Description
This message occurs while renaming the files specified in /etc/nvfail_rename.
- Corrective Action
(None).
- Syslog Message
Renaming files specified in /etc/nvfail_rename.
- Parameters
(None).
nv.rename.longName
- Severity
INFORMATIONAL
- Description
This message occurs while renaming the files specified in /etc/nvfail_rename, when the file name is too long.
- Corrective Action
(None).
- Syslog Message
nvfail_rename: %s: File name too long.
- Parameters
