disk.encryptgetmsidfailed events
disk.encryptgetmsidfailed EMS events occur when an encrypting disk reports a SCSI data protection error, but Data ONTAP® cannot obtain the Manufacturer's Secure ID (MSID) that is mandatory on disks that support storage encryption methods.
disk.encryptGetMSIDFailed
- Severity
NOTICE
- Description
This message occurs when an encrypting disk reports a SCSI data protection error, but Data ONTAP® cannot obtain the Manufacturer's Secure ID (MSID) that is mandatory on disks that support storage encryption methods. Some conditions can cause this error temporarily.
- Corrective Action
If the error persists, replace the disk or remove it from the system.
- Syslog Message
Unable to obtain MSID from disk %s; status "%s" (0x%x).
- Parameters
diskName (STRING): Name of the disk.
status_string (STRING): Status code description from the SCSI driver.
status (INT): Status code from the SCSI driver.
