ONTAP EMS reference
coredump.long events
coredump.long.queued.msg
Severity
NOTICE
This message occurs when the coredump manager thread detects that a message has been queued longer than expected, as defined by an internal threshold. System features and performance are not affected.
Corrective Action
(None).
Syslog Message
Coredump manager starts processing a long queued message: "%s" queued "%lu" ms.
message_type (STRING): Coredump message type.
queue_time (LONGINT): Message queued duration, in milliseconds.
threshold (LONGINT): Message queued threshold, in milliseconds.
coredump.long.running.msg
Severity
NOTICE
This message occurs when the coredump manager thread has finished processing a message that took longer than expected, as defined by an internal threshold.
Corrective Action
(None).
Syslog Message
Coredump manager finished processing a long running message: %s took %lu ms.
duration (LONGINT): Message processing duration, in milliseconds.
threshold (LONGINT): Message processing threshold, in milliseconds.
