ONTAP EMS reference
coredump.long events
coredump.long EMS events occur when ONTAP encounters issues associated with messages that take longer than expected to be queued or processed by the coredump manager thread.
coredump.long.queued.msg
Severity
NOTICE
This message occurs when the coredump manager thread detects that a message has been queued longer than expected, as defined by an internal threshold. System features and performance are not affected.
Corrective Action
(None).
Syslog Message
Coredump manager starts processing a long queued message: "%s" queued "%lu" ms.
message_type (STRING): Coredump message type.
queue_time (LONGINT): Message queued duration, in milliseconds.
threshold (LONGINT): Message queued threshold, in milliseconds.
coredump.long.running.msg
Severity
NOTICE
This message occurs when the coredump manager thread has finished processing a message that took longer than expected, as defined by an internal threshold.
Corrective Action
(None).
Syslog Message
Coredump manager finished processing a long running message: %s took %lu ms.
duration (LONGINT): Message processing duration, in milliseconds.
threshold (LONGINT): Message processing threshold, in milliseconds.
