coredump.long events
coredump.long EMS events occur when ONTAP encounters issues associated with the coredump manager thread processing messages that take longer than expected, as defined by an internal threshold.
coredump.long.queued.msg
- Severity
NOTICE
- Description
This message occurs when the coredump manager thread detects that a message has been queued longer than expected, as defined by an internal threshold. System features and performance are not affected.
- Corrective Action
(None).
- Syslog Message
Coredump manager starts processing a long queued message: "%s" queued "%lu" ms.
- Parameters
message_type (STRING): Coredump message type.
queue_time (LONGINT): Message queued duration, in milliseconds.
threshold (LONGINT): Message queued threshold, in milliseconds.
coredump.long.running.msg
- Severity
NOTICE
- Description
This message occurs when the coredump manager thread has finished processing a message that took longer than expected, as defined by an internal threshold.
- Corrective Action
(None).
- Syslog Message
Coredump manager finished processing a long running message: %s took %lu ms.
- Parameters
duration (LONGINT): Message processing duration, in milliseconds.
threshold (LONGINT): Message processing threshold, in milliseconds.
