ONTAP EMS reference
monitor.ioexpansionpower events
monitor.ioexpansionpower EMS events occur when ONTAP encounters issues associated with I/O expansion module power.
monitor.ioexpansionPower.degraded
Severity
NOTICE
This message indicates that power on the I/O expansion module is degraded.
Corrective Action
Degraded power might be caused by bad power supplies, bad wall power, or bad components on the motherboard. If spare power supplies are available, try exchanging them to see whether the problem is resolved. Otherwise, contact NetApp technical support.
Syslog Message
Power on I/O expansion module is degraded: %s
reasonText (STRING): Reading and state of voltage sensors on the I/O expansion module.
monitor.ioexpansionPower.ok
Severity
NOTICE
This messages indicates that power on the I/O expansion module is OK.
Corrective Action
No corrective action is needed.
Syslog Message
Power on the I/O expansion module is OK.
(None).
