monitor.ioexpansionpower events
monitor.ioexpansionPower.degraded
- Severity
NOTICE
- Description
This message indicates that power on the I/O expansion module is degraded.
- Corrective Action
Degraded power might be caused by bad power supplies, bad wall power, or bad components on the motherboard. If spare power supplies are available, try exchanging them to see whether the problem is resolved. Otherwise, contact NetApp technical support.
- Syslog Message
Power on I/O expansion module is degraded: %s
- Parameters
reasonText (STRING): Reading and state of voltage sensors on the I/O expansion module.
monitor.ioexpansionPower.ok
- Severity
NOTICE
- Description
This messages indicates that power on the I/O expansion module is OK.
- Corrective Action
No corrective action is needed.
- Syslog Message
Power on the I/O expansion module is OK.
- Parameters
(None).
