ONTAP EMS reference
mgmt.cifssymlink events
mgmt.cifssymlink EMS events occur when ONTAP encounters issues associated with CIFS symbolic link configuration.
Severity
ERROR
This message occurs when configuration of a CIFS symbolic link fails; the symbolic link might not be available through CIFS.
Corrective Action
Check the reason for the error and take action accordingly.
Syslog Message
Failed to configure CIFS symlink. Error: %s.
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
unix_path (STRING): The UNIX path.
Severity
INFORMATIONAL
This message occurs when a CIFS symbolic link is successfully configured after a failure.
Corrective Action
(None).
Syslog Message
(None).
