ctran.gc events
ctran.gc EMS events occur when ONTAP encounters issues associated with Cluster Transaction Manager (CTRAN) Group Coordinator operations.
ctran.gc.proposal.stuck
- Severity
EMERGENCY
- Description
This message occurs when the Cluster Transaction Manager (CTRAN) Group Coordinator (GC) of a group runs a prop-done probe for a proposal longer than anticipated.
- Corrective Action
KCS CTRAN logs need to be collected for further analysis. Trigger an ALL AutoSupport® message by using the "autosupport invoke -node * -message "ctran.gc.proposal.stuck" -type all" command. Also trigger a diagnostic AutoSupport by using the "autosupport invoke-diagnostic -node * -message "ctran.gc.proposal.stuck" -subsystem kcs" command. Then contact NetApp technical support
- Syslog Message
CTRAN group %s has attempted a prop_done probe %d times against gm_id %ld on node %s with UUID %s for txn %ld with opcode %d.
- Parameters
group_name (STRING): Name of the group being polled.
attempts (LONGINT): Number of attempts.
gm_id (LONGINT): Group member (GM) ID.
node_name (STRING): Name of the node the GM resides on.
node_uuid (STRING): UUID of the node the GM resides on.
trans_id (LONGINT): ID of the stuck transaction.
opcode (INT): Operation type of the stuck transaction.
ctran.gc.reselection.failed
- Severity
ALERT
- Description
This message occurs when some Kernel Cluster Services (KCS) Cluster Transaction Manager (CTRAN) groups lose their Group co-ordinator (GC) and a subsequent GC reselection process fails to complete.
- Corrective Action
Reboot the node, and if the node is waiting for giveback then perform a giveback.
- Syslog Message
CTRAN GC Reselection failed on local node (name=%s, id=%llu).
- Parameters
localhostname (STRING): The host name of the local node.
localnodeid (LONGINT): The node ID of the local node.
