ONTAP EMS reference
ctran.gc events
ctran.gc EMS events occur when ONTAP encounters issues associated with Cluster Transaction Manager (CTRAN) Group Coordinator operations.
ctran.gc.proposal.stuck
Severity
EMERGENCY
This message occurs when the Cluster Transaction Manager (CTRAN) Group Coordinator (GC) of a group runs a prop-done probe for a proposal longer than anticipated.
Corrective Action
KCS CTRAN logs need to be collected for further analysis. Trigger an ALL AutoSupport® message by using the "autosupport invoke -node * -message "ctran.gc.proposal.stuck" -type all" command. Also trigger a diagnostic AutoSupport by using the "autosupport invoke-diagnostic -node * -message "ctran.gc.proposal.stuck" -subsystem kcs" command. Then contact NetApp technical support support.
Syslog Message
CTRAN group %s has attempted a prop_done probe %d times against gm_id %ld on node %s with UUID %s for txn %ld with opcode %d.
group_name (STRING): Name of the group being polled.
attempts (LONGINT): Number of attempts.
gm_id (LONGINT): Group member (GM) ID.
node_name (STRING): Name of the node the GM resides on.
node_uuid (STRING): UUID of the node the GM resides on.
trans_id (LONGINT): ID of the stuck transaction.
opcode (INT): Operation type of the stuck transaction.
ctran.gc.reselection.failed
Severity
ALERT
This message occurs when some Kernel Cluster Services (KCS) Cluster Transaction Manager (CTRAN) groups lose their Group co-ordinator (GC) and a subsequent GC reselection process fails to complete.
Corrective Action
Reboot the node, and if the node is waiting for giveback then perform a giveback.
Syslog Message
CTRAN GC Reselection failed on local node (name=%s, id=%llu).
localhostname (STRING): The host name of the local node.
localnodeid (LONGINT): The node ID of the local node.
