osc.tcp events
osc.tcp EMS events occur when ONTAP is unable to connect to the IP address that the object store server hostname resolves to.
osc.tcp.connectFailed
- Severity
ERROR
- Description
This message occurs when ONTAP is unable to connect to the IP address that the object store server hostname resolves to.
- Corrective Action
Check if the object store server is listening on this IP address. Check network configuration.
- Syslog Message
TCP connection to object store server hostname "%s" fails over IP address "%s" on node "%s".
- Parameters
hostname (STRING): Hostname of the object store server.
ipAddress (STRING): IP address over which the TCP connection fails.
nodeUuid (STRING): Universal unique identifier (UUID) of the node.
