ONTAP EMS reference
osc.tcp events
osc.tcp EMS events occur when ONTAP is unable to connect to the IP address that the object store server hostname resolves to.
osc.tcp.connectFailed
Severity
ERROR
This message occurs when ONTAP is unable to connect to the IP address that the object store server hostname resolves to.
Corrective Action
Check if the object store server is listening on this IP address. Check network configuration.
Syslog Message
TCP connection to object store server hostname "%s" fails over IP address "%s" on node "%s".
hostname (STRING): Hostname of the object store server.
ipAddress (STRING): IP address over which the TCP connection fails.
nodeUuid (STRING): Universal unique identifier (UUID) of the node.
