ONTAP EMS reference
bsdsocket.queuelimit events
bsdsocket.queuelimit EMS events occur when the number of connection requests for a socket reaches the maximum number.
bsdsocket.queueLimit.reached
Severity
ERROR
This message occurs when the number of connection requests for a socket reaches the maximum number. These connection requests include partially completed connections and connections that are ready to be accepted. Network misconfigurations can cause ONTAP servers to slow down on a given TCP port and can be the cause of this message. This event can also be caused by a denial-of-service attack or an overloaded system.
Corrective Action
Try turning off and back on the LIF on which the last connection was received. If the issue remains after correcting any network misconfigurations, contact NetApp technical support.
Syslog Message
Number of connection requests for the socket bound to port %d having the IP address %s has reached the limit of %d connections. The last connection was received on IP address %s. The socket uses %s protocol. This event has occurred %llu times since the last warning.
port (INT): Local port bound to the socket.
ipAddress (STRING): IP address of the socket.
limit (INT): Maximum number of connection requests per socket.
childRecvIpAddress (STRING): IP address on which the last connection request was received.
protocol (STRING): Protocol used by the socket.
count (LONGINT): Number of occurrences for this event since the last warning.
