ONTAP EMS reference
bcomd.vdisk events
bcomd.vdisk EMS events occur when ONTAP encounters issues associated with LUN or NVMe namespace configuration replication in a MetroCluster configuration.
bcomd.vdisk.repl.failed
Severity
ERROR
This message occurs after a replication failure of a LUN or an NVMe namespace configuration in a MetroCluster™ configuration.
Corrective Action
Use the "metrocluster vserver resync" command to resynchronize the Vserver configuration for the affected Vserver.
Syslog Message
Replication of a LUN or an NVMe namespace configuration failed on Vserver "%s". Reason: %s.
vserver (STRING): Name of the Vserver.
error (STRING): Error encountered while replicating the configuration.
bcomd.vdisk.transition
Severity
NOTICE
This message occurs when a user attempts to convert a LUN into an NVMe namespace or vice-versa.
Corrective Action
(None).
Syslog Message
Conversion for "%s", Vserver "%s" to type "%s" completed with status "%s".
source_vdisk_path (STRING): Path to the LUN or NVMe namespace to be converted.
destination_vdisk_type (STRING): Destination vdisk type after conversion.
status (STRING): Status of conversion operation.
