nblade.nfs4unoptimizedio events
nblade.nfs4unoptimizedio EMS events occur when a session trunking group that is created by the NFSv41 client is split across multiple nodes.
Nblade.nfs4UnOptimizedIO
- Deprecated
Deprecated as of version 9.18 as this ems message need N2N infrastructure bootarg, but this is disabled completely and we cannot repro this ems message. Hence, ems message should be removed.
- Severity
ALERT
- Description
This message occurs when a session trunking group that is created by the NFSv41 client is split across multiple nodes. This can occur when one or more trunked data LIFs used in the trunking group migrate to the partner node. A split session trunking group can severely degrade performance of NFS client operations.
- Corrective Action
Address any network or hardware issues that might have caused the LIFs to migrate. Ensure trunked data LIFs are on the same node. Use the "network interface show" and "network interface migrate" commands to revert the migrated LIF to the original node where the trunking relationship was created for that LIF.
- Syslog Message
In-flight requests from client IP [%s]:%d to destination LIF "%s" (Vserver: %s) was using an unoptimized path for processing the request because of a split session trunking group. The NFSv4 client might experience degraded performance.
- Parameters
clientIpAddress (STRING): IP address of the client.
clientPort (INT): Network port of the client.
lifIpAddress (STRING): IP address of the logical interface.
vserverName (STRING): Name of the Vserver associated with this operation.
