mlm.scsi events
mlm.scsi EMS events occur when ONTAP encounters issues associated with SCSI INQUIRY data support levels.
mlm.SCSI.supportLvl.bad
- Severity
ALERT
- Description
This message occurs when an array target port contains SCSI INQUIRY data with an incorrect support level. To prevent a possible data corruption scenario, the target port is not used.
- Corrective Action
Verify that the SPC-2 bit in the array's host group is set.
- Syslog Message
The target port containing SCSI INQUIRY DATA %s:%s with a (WWPN) of %s, has an incorrect SCSI support level; it will not be available.
- Parameters
vendorId (STRING): Vendor ID from the SCSI INQUIRY data.
productId (STRING): Product ID from the SCSI INQUIRY data.
wwpn (STRING): World Wide Port Name (WWPN) of the target port that has the incorrect SCSI support level.
mlm.SCSI.supportLvl.good
- Severity
NOTICE
- Description
This message occurs when an array target port that previously contained SCSI INQUIRY data with an incorrect support level has been corrected.
- Corrective Action
(None).
- Syslog Message
The target port containing SCSI INQUIRY DATA %s:%s with a (WWPN) of %s, now has a correct SCSI support level.
- Parameters
wwpn (STRING): World Wide Port Name (WWPN) of the target port that now has the correct SCSI support level.
