ONTAP EMS reference
mlm.scsi events
mlm.scsi EMS events occur when ONTAP encounters issues associated with SCSI INQUIRY data support levels.
mlm.SCSI.supportLvl.bad
Severity
ALERT
This message occurs when an array target port contains SCSI INQUIRY data with an incorrect support level. To prevent a possible data corruption scenario, the target port is not used.
Corrective Action
Verify that the SPC-2 bit in the array's host group is set.
Syslog Message
The target port containing SCSI INQUIRY DATA %s:%s with a (WWPN) of %s, has an incorrect SCSI support level; it will not be available.
vendorId (STRING): Vendor ID from the SCSI INQUIRY data.
productId (STRING): Product ID from the SCSI INQUIRY data.
wwpn (STRING): World Wide Port Name (WWPN) of the target port that has the incorrect SCSI support level.
mlm.SCSI.supportLvl.good
Severity
NOTICE
This message occurs when an array target port that previously contained SCSI INQUIRY data with an incorrect support level has been corrected.
Corrective Action
(None).
Syslog Message
The target port containing SCSI INQUIRY DATA %s:%s with a (WWPN) of %s, now has a correct SCSI support level.
wwpn (STRING): World Wide Port Name (WWPN) of the target port that now has the correct SCSI support level.
