ONTAP EMS reference
vifmgr.reach events
vifmgr.reach EMS events occur when ONTAP encounters issues associated with network port reachability scanning and broadcast domain connectivity.
vifmgr.reach.avail
Severity
NOTICE
This message occurs when the node has completed its initial scan of reachability for all ports.
Corrective Action
(None).
Syslog Message
Node %s has completed its initial scan of reachability for all ports.
node (STRING): Name of the node on which the network port resides.
vifmgr.reach.err
Severity
ERROR
This message occurs when a network port encountered errors while scanning for reachability.
Corrective Action
Verify the network port's physical connectivity and switch configuration. A network port should have reachability only to its expected broadcast domain.
Syslog Message
Network port %s on node %s encountered errors while scanning for reachability. Reachability was detected to the following broadcast domains: %s.
port (STRING): Name of the network port.
reachableBroadcastDomains (STRING): Names of the broadcast domains that are reachable from the port.
vifmgr.reach.miscfg
Severity
ERROR
This message occurs when a network port cannot reach its expected broadcast domain but has reachability to another broadcast domain.
Corrective Action
Syslog Message
Network port %s on node %s cannot reach its expected broadcast domain %s, but reachability was detected to broadcast domain %s.
broadcastDomain (STRING): Name of the broadcast domain associated with the port.
vifmgr.reach.miscfg.unassn
Severity
NOTICE
This message occurs when a network port is not assigned to a broadcast domain but has reachability to a broadcast domain.
Corrective Action
Syslog Message
Network port %s on node %s is not assigned to a broadcast domain, but reachability was detected to broadcast domain %s.
vifmgr.reach.multireach
Severity
ERROR
This message occurs when a network port is determined to have reachability to multiple broadcast domains.
Corrective Action
Syslog Message
Network port %s on node %s can reach the following broadcast domains: %s.
vifmgr.reach.noreach
Severity
NOTICE
This message occurs when a network port cannot reach its expected broadcast domain or any other broadcast domain.
Corrective Action
Syslog Message
Network port %s on node %s cannot reach its expected broadcast domain %s. No other broadcast domains appear to be reachable from this port.
vifmgr.reach.ok
Severity
NOTICE
This message occurs when a network port's actual broadcast domain reachability matches its expected reachability, and no other broadcast domains appear to be reachable from the port.
Corrective Action
(None).
Syslog Message
Network port %s on node %s can reach its expected broadcast domain %s. No other broadcast domains appear to be reachable from this port.
vifmgr.reach.skipped
Severity
NOTICE
This message occurs when a network port was not scanned for reachability because it was administratively or operationally down at the time of the scan.
Corrective Action
(None).
Syslog Message
Network port %s on node %s was not scanned for reachability because it was administratively or operationally down at the time of the scan.
vifmgr.reach.unassn
Severity
NOTICE
This message occurs when a network port is not assigned to a broadcast domain, and has no reachability to any broadcast domains.
Corrective Action
(None).
Syslog Message
Network port %s on node %s is not assigned to any broadcast domain. No broadcast domains appear to be reachable from this port.
