vifmgr.reach events
vifmgr.reach.avail
- Severity
NOTICE
- Description
This message occurs when the node has completed its initial scan of reachability for all ports.
- Corrective Action
(None).
- Syslog Message
Node %s has completed its initial scan of reachability for all ports.
- Parameters
node (STRING): Name of the node on which the network port resides.
vifmgr.reach.err
- Severity
ERROR
- Description
This message occurs when a network port encountered errors while scanning for reachability.
- Corrective Action
Verify the network port's physical connectivity and switch configuration. A network port should have reachability only to its expected broadcast domain.
- Syslog Message
Network port %s on node %s encountered errors while scanning for reachability. Reachability was detected to the following broadcast domains: %s.
- Parameters
port (STRING): Name of the network port.
 reachableBroadcastDomains (STRING): Names of the broadcast domains that are reachable from the port.
vifmgr.reach.miscfg
- Severity
ERROR
- Description
This message occurs when a network port cannot reach its expected broadcast domain but has reachability to another broadcast domain.
- Corrective Action
- Syslog Message
Network port %s on node %s cannot reach its expected broadcast domain %s, but reachability was detected to broadcast domain %s.
- Parameters
 broadcastDomain (STRING): Name of the broadcast domain associated with the port.
vifmgr.reach.miscfg.unassn
- Severity
NOTICE
- Description
This message occurs when a network port is not assigned to a broadcast domain but has reachability to a broadcast domain.
- Corrective Action
- Syslog Message
Network port %s on node %s is not assigned to a broadcast domain, but reachability was detected to broadcast domain %s.
- Parameters
vifmgr.reach.multireach
- Severity
ERROR
- Description
This message occurs when a network port is determined to have reachability to multiple broadcast domains.
- Corrective Action
- Syslog Message
Network port %s on node %s can reach the following broadcast domains: %s.
- Parameters
vifmgr.reach.noreach
- Severity
NOTICE
- Description
This message occurs when a network port cannot reach its expected broadcast domain or any other broadcast domain.
- Corrective Action
- Syslog Message
Network port %s on node %s cannot reach its expected broadcast domain %s. No other broadcast domains appear to be reachable from this port.
- Parameters
vifmgr.reach.ok
- Severity
NOTICE
- Description
This message occurs when a network port's actual broadcast domain reachability matches its expected reachability, and no other broadcast domains appear to be reachable from the port.
- Corrective Action
(None).
- Syslog Message
Network port %s on node %s can reach its expected broadcast domain %s. No other broadcast domains appear to be reachable from this port.
- Parameters
vifmgr.reach.skipped
- Severity
NOTICE
- Description
This message occurs when a network port was not scanned for reachability because it was administratively or operationally down at the time of the scan.
- Corrective Action
(None).
- Syslog Message
Network port %s on node %s was not scanned for reachability because it was administratively or operationally down at the time of the scan.
- Parameters
vifmgr.reach.unassn
- Severity
NOTICE
- Description
This message occurs when a network port is not assigned to a broadcast domain, and has no reachability to any broadcast domains.
- Corrective Action
(None).
- Syslog Message
Network port %s on node %s is not assigned to any broadcast domain. No broadcast domains appear to be reachable from this port.
- Parameters
 PDFs
PDFs
