lmgr.nl events
lmgr.nl EMS events occur when the number of mirrored open lock count reaches the maximum supported limit.
lmgr.nl.open.limit.hit
- Severity
NOTICE
- Description
This message occurs when the number of mirrored open lock count reaches the maximum supported limit.
- Corrective Action
Run the "vserver locks show-mirrored-open-count -detailed" command to check the mirrored open lock count and try closing the unused files to bring this count down to the currently supported maximum mirrored open locks.
- Syslog Message
The number of mirrored open locks count %u has reached the limit %u for pool %s. The current number/limit of other lock manager objects are: files %u/%u hosts %u/%u locks %u/%u owners %u/%u.
- Parameters
nl_locks_total (INT): Number of mirrored open locks.
nl_locks_limit (INT): Maximum supported mirrored open locks.
pool_name (STRING): Name of the limit pool.
files_total (INT): Number of allocated files in the pool.
files_limit (INT): Allocated files limit for the pool.
hosts_total (INT): Number of allocated hosts in the pool.
hosts_limit (INT): Allocated hosts limit for the pool.
locks_total (INT): Number of allocated locks in the pool.
locks_limit (INT): Allocated locks limit for the pool.
owners_total (INT): Number of allocated owners in the pool.
owners_limit (INT): Allocated owners limit for the pool.
