ONTAP EMS reference
lmgr.nl events
lmgr.nl EMS events occur when the number of mirrored open lock count reaches the maximum supported limit.
lmgr.nl.open.limit.hit
Severity
NOTICE
This message occurs when the number of mirrored open lock count reaches the maximum supported limit.
Corrective Action
Run the "vserver locks show-mirrored-open-count -detailed" command to check the mirrored open lock count and try closing the unused files to bring this count down to the currently supported maximum mirrored open locks.
Syslog Message
The number of mirrored open locks count %u has reached the limit %u for pool %s. The current number/limit of other lock manager objects are: files %u/%u hosts %u/%u locks %u/%u owners %u/%u.
nl_locks_total (INT): Number of mirrored open locks.
nl_locks_limit (INT): Maximum supported mirrored open locks.
pool_name (STRING): Name of the limit pool.
files_total (INT): Number of allocated files in the pool.
files_limit (INT): Allocated files limit for the pool.
hosts_total (INT): Number of allocated hosts in the pool.
hosts_limit (INT): Allocated hosts limit for the pool.
locks_total (INT): Number of allocated locks in the pool.
locks_limit (INT): Allocated locks limit for the pool.
owners_total (INT): Number of allocated owners in the pool.
owners_limit (INT): Allocated owners limit for the pool.
