ONTAP EMS reference
clam.heartbeat events
clam.heartbeat EMS events occur when the Kernel Cluster Services Connectivity, Liveliness, Availability Monitor (CLAM) detects that the state of the heartbeats to a node changed(that is, either the heartbeats started succeeding or they started failing).
clam.heartbeat.state.change
Severity
INFORMATIONAL
This message occurs when the Kernel Cluster Services Connectivity, Liveliness, Availability Monitor (CLAM) detects that the state of the heartbeats to a node changed(that is, either the heartbeats started succeeding or they started failing).
Corrective Action
Take one or more of the following actions: - A repeated toggling of the heartbeat state indicates intermittent network issues. Check the connectivity of the node to the cluster interconnect and fix any problems. - In all the other cases, the heartbeat failure will eventually result in the node going out of quorum. If that happens, take the actions prescribed for "EMS_clam_node_ooq event".
Syslog Message
Heartbeats to node (name=%s, ID=%llu) are %s.
hostname (STRING): Host name of the node.
nodeid (LONGINT): Node ID of the node.
state (STRING): New state of the heartbeats to this node.
